I've just bought 1 key for now and it's an OEM, any solution for this?
could try this link, not too sure if it will work but had a quick google search
http://getintopc.com/softwares/oper...8-1-oem-core-single-language-64-bit-download/
MS have disabled new activations until the 29th.
How did my in place upgrade from Windows 8.1 to Windows 10 activate then?![]()
I have been completely out of the loop. An icon appeared asking if I would like to upgrade 8.1 to 10, a while back. So come July 29th, I simply download through Microsoft?
.Yep. It will be delivered through Windows Update. It might take a few days after the 29th for it to pop up, as Microsoft will be staggering the release to avoid DDoSing themselves.
you will need to get a OEM ISO as others have said retail ISO's don't work with OEM keys
It has been mentioned on a few forums that it will start pre-loading possibly next week ? An MS employee said "Everyone should have the files in place before the 29th"
Hopefully this is true as it will make things a lot easier server load wise on the 29th onwards...
I believe you need to be on the insider programme previously, I could be wrong, worth a shot if you have nothing to lose.![]()
Skeeter, how do I see my build number out of Curiosity?
From build 10130 onwards you HAVE to sign into an Insider Preview build using a Microsoft Account registered as part of the Insider Program. So if your not in the Program I'm pretty sure you won't get it to activate at all.
cheers skeeter, ill wait till after the 29th then and install the final ISO\download it from windows update
edit.....or I could just run it un activated and then activate it on the 29th when it opens up again?
