- 1 May 2013
- M28
Got a 20% ebay voucher, any recommended sellers for an 0805/6? pref Chinese since about £20 cheaper
The 1080P HDR mode works surprisingly well in dusk/night time conditions. Where highlights would be overly blown out in normal mode, with HDR they're not and signs are more legible. Just a shame it's 30fps only of course but at least the quality is good.
I'm undecided between 1920x1080-HDR and 2560x1080 now, the latter is 24Mbit and 1080 is a shade over 10Mbit, so the 2560 res is a little more detailed, but the HDR offsets that with a more clearer picture as darkness falls. The HDR resolution file is also half the size of the 2560 one (250MB vs a little over 500MB for 3mins per file), so more recording time available.
I wish someone would create a firmware with the changes in the custom one mentioned already, and with the addition of a day/night setting whereby as night hits, you can tell it to use one resolution, and daytime another.
I'll retry without using the CPL at night and apply -1EV to offset the blown highlights. The key is to be able to read signs and things and not worry about detail in dark areas so this may work out well, even during the day.
I meant the recording of it, do you set it so it shows a lot of dash or not a lot?
Have you/anyone asked the guy on the forum who created the 24mbit custom firmware?
At least he might be able to update the bitrate of the 1080p-HDR files to improve detail... you never know about the switching functionality, although that sounds more complicated, whereas the bitrate update may literally be changing the bitrate figures from 10mbit to 24mbit![]()
Not had the issue with sd card on mine! At least I don't think I have yet.
Like mine?
I use registration Viewer. It's pretty neat, download and set up the options how you like, points the file browser to your sd card and the software will group all session segments into "one" video and plot out the Map route, G data, stats etc - This is really cool.
You can then use the timeline right click option to set a start point and end point then right click and save only the segment between those points. KB shortcut is CTRL+HOME/END.
If you weren't talking to me then... ¯\_(ツ)_/¯![]()
