Mrs back and seems happy.. looking forward to the macky dinner
Oddly - it's the first time I've caught mackerel (on the boats I never seem to have the knack).
Equipment washed down, tried and rod rings WD40'd.
So the spinning rod at 1-2oz casting is awesome fun
The mackerel you could feel but it could cope with far bigger fish. It was funny the two oriental guys in the next bay kept watching the casting - seemed to me that I was going further with 2oz and feathers etc than he was going with a far bigger rod and reel. The rod looks like an LRF but it's definitely a boat rod!
Had chance to play with the uptide using the lower handle. After trying 3,5,6,9,10-12oz (can't read it so should measure it at some point) it's casting is between 5-10oz rating showed it was very happy with 6-9oz and I think would do 10oz on a boat just to get away from the boat.
The multiplier cast was funny - initially the casts were slow spooling.. as I got better and found the 6oz weight, with a short drop to the lead, resulted in the spooling getting faster and faster - the last cast was nuts with the reel screaming. The old Pen 160 is probably at it's limit (as Cainer noted). Will try the warbird next but for now that's a decent boat cast distance for up tiding and far better than I was doing previously.
The uptide smaller rings mean I will need to look carefully at how I tie the knots, I had several interesting mishaps with the lead slamming the harbour wall thanks to a knot sticking in the rings.
I could have put the hyper loop FS reel on the uptide but I was concerned that the 20lb braid would cut my finger and the strain may be too much. It was starting to dig in on the spinning rod casting but not too bad.
The norwegian pirk came into it's own for snags - wrapping the braid around it and then leaning back to free the snag (50lb braid!) or snap the braid at the knot (20lb braid) without causing too much abrasion. The wall has braided the 20lb a bit at close range.. so I will keep an eye on that.
That area is not a good place to use treble hooks - I even lost my sparkly cod spoon (single 6/0 or 8/0 hook) I was using as an attractant - should have taken off the hook.
So I need to restock some weights, some feathers, vibe eels, a bass/cod spoon, ...
Definitely up for a next time out.. if a boat position comes available I'd be happy to put forward you both. Mental note - take some change and lower denominations as the bailiff doesn't have change - I also feel I owe you some diesel!
