Depends how long is a piece of string?
Smaller IS smaller is it not?
But is it MUCH smaller?
'Much', defined as '1. A large amount'. I wouldn't class <10% as a large amount in this case. But hey ho.
I used to have an e46 325i manual Touring, 2000 m/y, changed it for an e39 530i Sport Auto of the same age, a few more miles and despite the 5 being heavier (but only by 100kg or so!) and being automatic, it feels noticeably quicker than the 325 was, never bothered to check the actual figures tbh but seat of the pants as such, the bigger engined 5 feels the quicker to me, despite being much more refined...
Fair enough, just isn't my experience of them - I guess the 3 litre feels a bit more muscular but there's little in it in terms of feel imo and I'd be willing to be there would be very, very little in it if they were both on the road
My friend had a 325 manual and has recently changed to a 530 auto and there's not much in it. 0-100, my Jag would pull out a few car lengths on his old E46, but with his 530 they're pretty much dead level the entire way. So the 530 is definitely faster than the 325, but not by that much.
[TW]Fox;28432715 said:The new 330i is a 4 pot![]()
That sucks, could have at least been a v6![]()
That sucks, could have at least been a v6Is the chain expected to last the life of the engine? Thank god it isn't a belt, that would suck royally
If it's anything like the one in the old x20d's it could get very expensive for people
[TW]Fox;28432869 said:BMW have used chains for decades and only that particular engine has ever had issues with them. It's generally a non-issue and far better than belt drive.
If I get the z4, we're definitely going for a jaunt around the wicklow mountains.
Though I might be a bit outpowered.
(this one is a private sale through work, he wants 6.5k, but I reckon he'll take 6k). Only other one I can see is in Mayo, but the 4 owners is putting me off. The rest have 100k+ mileage which isn't the end of the world, but my cars get driven hard so would like as much leeway as possible.![]()
I'd low ball the guy, they aren't that easy to shift over here!Yeah scuff them up and ofc degrease the drum surface. Not wrenched on a wheel bolt, probably just knacker the taper on it. Normally I'd just stick a couple of bolts in and use a bar between them, if you can't move it with 18" of leverage then it's definitely tight. Seriously though if you want to use a torque wrench then just whack it on the hub nut.
Sounds good man, go get one! Wicklow mountains are all about momentum so I reckon you'll be OKI'd low ball the guy, they aren't that easy to shift over here!
Have you seen the cheap one down in Waterford? It's dirt cheap and leaves lots of cash for improvements.
