Got the last few bits for camping/touring on the bike, that being a self inflating camping mat, some more merino wool base layers (mountain warehouse, £25 each for L/S top and bottoms, with 20% off all weekend if anyone's interested
) and a microfibre towel.
Test fitted the kriega US30 with all my camping stuff, which is:
tent
sleeping bag
roll mat
towel
+ plus still some space for a few odds and ends - a normal size 3 season sleeping bag would probably fit in with the rest of the bits, my one is a tiny summer sleeping bag.
That's not fully tightened down at the front, it's not budging when it's fully tight. A couple of US20's would go very nicely on that
My Kriega R30 sits on top when I'm riding, just need to make the straps slightly smaller, and it takes 100% of the weight of the rucksack.
Also picked up a cheap rollbag for my waterproofs - I'll be keeping them in my tank bag and if they're wet i need to keep the moisture away from phone/wallet/passport etc, £3.99 from sports direct for a 5 litre rollbag, which is perfect for the richa rain warrior top and bottoms.
They have sizes from 2 litres up to 25 litres, all under a tenner so if you need a cheap waterproof roll bag have a look. I may pick up a couple more, they're handing for keeping wet stuff with dry things or as another layer to protect from rain.
And yes, I know my bike needs a damn good wash!
