It should still remain waterproof I would have thought
Not easy if you're drilling holes in the case for a USB connection.
Kreeeeeeee - you have a chin mount don't you? You ever done a video on your chin mount and mic/audio set up?
I'd only go for a chin mounted gopro or lookalike, just not sure the best way to attach it. My helmet has space for a front adhesive pad.
Bit of clear silicone sealer? That's if you keep the wire permanently attached
	I use adobe premiere, but you have to pay for that. Sony Vegas is also very good and not too expensive I don't think.
I jsut got my Yi today. Will put it on my bike at the weekend. Hopefully there's some good weather. I'll show you all what 0-60 looks like on a 40 year old bike with a wobbly tach and speedo needles![]()
 i'll do a 0-60 on my duke 125, the video may be 40 minutes long.
). I was able to film in 1080p 30fps for 1 hour twenty minutes. I'm not sure if that's good or bad it cut out before I got home though.
