Permabanned
- 8 Jan 2010
- UK
Is this worth £38 HCigar HB40 DNA40?
Nice, my D2 has more of the "just been mugged" urban look about it, dropped it twice while drunk, paints chipped and the battery door had to get re shaped, still works perfectly though![]()
STOP TEMPTING ME TO THE DARK SIDE![]()
Seem to have an issue.
Using the sub-ohm standard 0.5 Coil which reads in at 0.22 when firing the voltage additionally starts high then instantly drops to 1.62 and dosen't fire any higher reglardless of my wattage settings etc on the Segelei 75w with some adequate batteries according to the specifications.
Any ideas?
What tank and battery?
That's a Kanthal coil so you don't need to use it in Temperature mode
I thought I'd give mine a bit of a torture test and throw an RDA on with a build that could take plenty of power. The batteries are sagging extremely hard at 100w. Resting they we're showing 3.7v on both cells and while firing they're dropping to 3.11v and 3.15v
snip
snip
Thank you kindly.
Anyone have a link to the best velocity one on FT?.
I cant seem to find the tobeco clone if its still there.
Only question i had was how do i tell if i'm near the limit of my battery with these custom dual coils? Normally it would be 4.2v/0.5 = 8.4 amps. My VTC4 should handle 20a but does the dual build affect matters?
You are not going to get much difference in flavour, unless you can taste the wire as some can (I get a chemical taste from NI200 so prefer Titanium as it tastes cleaner to me), the whole point really is no more burnt hits or boiling juice to release harmful crap...
iirc myepack had/have the tobeco clone for around £14![]()
My first port of call but sold out
If the tobeco one is the one to get, i'll grab it from someplace else in the UK, fasttech was confusing me. Will buy my D2 and some other drippers from there though .
Does anyone know where to get pre built clapton coils from?
are there different versions of the dna40? I am thinking of buying one. Can the firmware be updated on them?
This is the one I'm looking at which is a further 50% off
http://www.gearbest.com/electronic-cigarettes/pp_159310.html
Also I watched pbuardos video on TC and DNA40 and he said the coils cannot be micro coils and is more fiddly to work with Nickel. Is that true and is Nickel as easy to handle as Kanthal on the Kuro coil tool?
