I believe there is an official price cut on 9th October so you may want to hold off for a few days. I'll be jumping onboard thenAny good PS4 bundle deals on at the moment?
Jay
Jay
Thanks, any recommendations on a 2TB drive. Quicker the better![]()
Yeah I had considered upgrading to a sshd but I haven't looked into if the performance upgrade is worth it.
the quickest you can get requires a nyko data bank which you can order from america for less than £40.
i load about 6 seconds quicker into the tower in destiny for example when i'm host in a fireteam of 3 or less.
I'm sure it is a permanent drop, it just coincides with the Nathan Drake bundleIt's worth mentioning that the Eurogamer article I linked to also mentions that the Nathan drake bundles have a discount but its not permanent drop and no word of one here.
It appears current bundles are around £50 lower that rrp, hopefully this will carry through with the official price drop. I'm thinking we may see the 500gb for £249? Which is the kind of sweet spot I'm looking for.The Uncharted bundles are the reduced prices (supposedly), so £299 for 500GB and £329 for 1TB. Both new models.
As far as I know only 2.5" 2TB drive available that fits is the Seagate / Samsung M9T (as found in the Seagate USB External Drive) - Toshiba and WD both make 2TB 2.5" drives but they are 15mm tall and therefore won't fit.
The 2TB Seagate is faster than the stock 500GB drive despite still being 5400rpm, due to the higher data density.
2TB SSHD's aren't available in 2.5" yet, and the 1TB is about the same price as the 2TB Seagate Hard Drive. If you can get a good deal on one (vs a standard 1TB drive) then there is nothing to lose, but the PS4 is not optimised for them (or SSD in general), so don't expect huge gains.
The quickest in certain circumstances - benchmarks are mixed e.g.
http://uk.ign.com/articles/2015/06/09/nyko-data-bank-for-playstation-4-review
Loading even 6 seconds faster, doesn't make up for the unattractiveness of the Data Bank.
Got my new shiny ps4 today. Doing system update to 3.0
How long should this take? 40 mins and counting...
benchmark was using a mechanical drive.
i have a hybrid.
Erm, 2 minutes.![]()
So there's 2 OcUK communities now?![]()
Is 3.0 update out now?
Ive been away and not turned my ps4 on yet, if so is it a good update.
thanks
yeah, and seems so
The truth is that the PS4 is optimised to get the best out of the standard hard drives, slotting in Hybrids that have firmware optimised for Windows PCs (i.e. to accelerate boot and folder opening for example) just doesn't make as big a difference.
It's more that the 8GB cache isn't really enough to make a particularly noticeable difference in games which are often many times bigger than that. I've got one in my PS4 but the gains were actually more noticeable when it was in the PS3.
PS3 game installs were fairly terrible though, unpacking thousands of files all over the hard drive, whereas PS4 uses similar methods to PC, just storing larger archive files .
http://www.eurogamer.net/articles/digitalfoundry-ps3-hard-drive-upgrade-guide?page=2
43 minute install time for GT5![]()
Also since the firmware 3.0 psn downloads are considerably quicker as well..
