The board should have the plate? You could cut the screws up to the stubby part or put holes through the mobo as that's what I'm going to do if it's compatible that isI'm using this Asus TUF X99 Sabertooth Intel X99 board now.
But sods law i can't install it, as there is now holes
Is there any other way to install this cooler?
Thanks.
edit, just realised it needs the 2011 plate, and guess what, the board don't have one lol..
Just checked a rear view on the Asus TUF X99 Sabertooth Intel X99 and it looks like you can push through the mobo with a screwdriver![]()
I'll get some on my next order from EK
My EK Water Blocks Predator 240 started making a clicking noise from the pump yesterday, and i noticed some water coming from the cpu block.
so i tightened it up, and it stopped leaking.
But the noise on the pump kept clicking.
Was still working ok thou. the clicking stopped after a while.
Turned the pc on today, and kept freezing! then i noticed the temps on the cpu 5820k were hitting 95 degrees.
so i felt the cpu block and it was so hot, but the pipes were cool.
after a lot of testing, i then notice the pump must have stopped working!
So now the pumps dead it seems.
Is there anything i can do? or just have to RMA. ?
Cheers.
Seems like an RMA jobbie to me.
It wouldn't of caused a problem on the cpu would it ? going over 95 degrees ?
Cheers.
Cheers.
The pump on these are so nice and silent thou.
Cheers.
This doesn't sound too good... two recent examples of defective units. Maybe being a new product there are some issues to be ironed out? EK have a good rep and usually produce solid and reliable stuff, so this surprises me. Anything with water in is certainly NOT something you want to be going wrong in your system!
