They should really change the tubing and that quick disconnect. It's so ugly![]()
the tubing is there as it is non porous so works well in that it doesn't lower the coolant level and starve the pump over time. essential for a closed loop with zero maintenance.
the QDC is not very nice looking. BUT the important thing to remember is that it every QDC on the market loses around a teaspoon of fluid when disconnected.
This one doesnt which is absolutely essential as this is designed to be installed in the case with pre filled blocks.
If I get the 240 Predator, can I change the tubing/liquid to my taste? Or is that a no go?
it's just somewhat loudThere was initially an OCUK Tech Labs version which you could have customised, but that got pulled by request of EK. There was talk of it coming back, but I haven't heard any more, so not sure what's happening there. RJK also said he might post a tutorial/guide on how to mod ourselves. Personally, I'd love to see the Tech Labs version return... I don't really fancy messing around with tubing and coolant if I don't have to, which is the whole appeal of an AIO in the first place.
I think Koolance QD3/4 has resolved that already?
All you loss is 2 drops of fluid
pvc tubing is porous which is why we cant use it...
and also explains why ek chose their tubing for the predator
Ah, so that applies to ALL clear tubing? Why would ANYONE use this for WC'ing in that case, why does it even exist?
Cause it looks cool.
With a custom water cooling loop you can easily top up.
Anything that states itself as "None maintenance" should have that kind of tubing.
It also makes it easier to see air bubbles, see water movement etc.
The amount it is "Porous" is approx. x number of atoms per days.
You are not suddenly going to have a wet case no![]()
Unsure which fittings would need.....and which pipe.....
