** POTENTIALLY THE BEST GAMING MONITORS YET!! ** Acer 34" Ultra-wides
I just wanted to give my thoughts on this screen. I have it now for 2 days. Overall very happy with it. Here are my findings.
I am coming from a 2560x1440 Crossover 27Q LED-P. The difference is huge. There is so much more screen real estate. Games are much more immersive. So far my favorite has been GTA V. There are times just have to stop and look around at how beautiful the game is and the screen really makes it shine. The higher refresh rate is definitely noticeable even at the desktop but in game I have not played enough with the mouse to say how much better it is. In GTA I use the controller so I can’t really feel it but everything runs really smooth.
Blue Banding: Not present so firmware upgrade has been applied.
BLB: Very little on the top left on a black screen. Only noticeable if you are looking for it. I found that if you apply very light pressure to the screen it will go away so perhaps the hairdryer trick that some people try would work. It doesnt bother me enough to go messing with it however.
IPS glow: Noticeable glow mostly from the bottom left on a dark/black screen if you look at the screen slightly from above and to the right. Otherwise it is not noticeable. If you are looking straight on there is very little and you barely notice it even when looking for it on a totally black screen. Between this and the BLB the glow is certainly more noticeable if you look at it from certain angles and on a dark or black background. I don't notice it at all during normal use.
Video showing the BLB and IPS Glow
Overclock: I can only select 95 Hz in the Nvidia control panel despite being able to set it to 100 HZ on the OSD. Perhaps this is my GTX 670’s or perhaps my screen just can’t reach 100 Hz. I thought most people could select 100 Hz but may have some side effects and have to lower to 95 Hz. If anyone discovers anything about this please let me know.
Coil Whine: At 95 Hz I can’t notice anything even on a while screen unless I turn my head to the side and put my ear close to the screen. Even then it is a very slight noise, doesn't sound like the coil whine like you hear from some graphics cards it is a very low noise. Doesn’t bother me in the slightest but perhaps it is worse for some people.
Backlight/Sleep Problem: I have seen this twice so far, once when I first plugged in the monitor for the first time before I had even powered the pc on. The predator logo came on and the right side of the screen didn’t light up but once I powered on the PC it corrected itself. The second time was when my monitor came out of sleep after being idle in windows. Both times it was the right half of the screen that didn’t light up. I just powered the screen off and on again to fix. I have also had it wake from sleep correctly with no issues. It looks like a lot if not all people are experiencing this and acer are looking into it so hopefully it will be an easy fix.
Here are some Images
Could you please record your monitor with your phone or a camera and then screenshot (or upload footage to the tube) and upload here?
From a normal face-position, distance and angle with a black background?
Too bright outside now. I have a window behind my screen, the light is messing with my camera even through curtains. I can get a recording later for you.
Anyway so far the good ones vs the bad ones seems good, on here at least.
Maybe its because the US got them first and people have had time to let the little niggles turn into bigger annoyances.
The waking up issue seems to have got most people riled. Although if you look at the previous acer thread there is one guy who posted really bad BLB you could even see it when gaming never seen BLB so bad on a monitor before.
Few threads on here though for the X34
http://community.acer.com/t5/Predator-Discussions/bd-p/predator
Speculation over whether the flickering and wake up issue was caused by the V2 firmware.
Did Badass have any issues with the V1 monitor waking up for instance ?
The Acer forum bods are in the direct firing line dont fancy there jobs.
Question you have to ask is are you happy with your monitor because the picture quality/gaming experience exceeds your expectations despite the niggles and are not bothered about paying £989 for an imperfect monitor?
There isn't a perfect monitor though so we are all to a certain extent paying however much for imperfection.
I found a 21:9 fix for MGSV and it was just amazing on this monitor. So much more immersive, great picture quality, smooth as a button and locked at 60 with everything maxed.
The only issue I might have with mine is the sleep thingy but I haven't tested for it yet. It doesn't bother me as long as there is no long term impact on the monitor.
V1 firmware did the same thing with waking up. it's hardly a massive issue though. i found it would sometimes do it when resuming from standby, but then when you logged in to windows from suspend, and it initiated a very quick blank screen before logon, most of the time that sorted it. if not, a quick power off/on of the screen fixed it. just turn the screen off instead of letting it go in to standby when pc is put to sleep.
It is dark enough now that I could do a video.
The Glow is certainly the most noticeable if you look at the screen from above and to the right but its ok looking straight ahead and during normal use.
Looks good. Noticable glow like you said, and very little bleed - just some in the corners. Hopefully mine is as good when it arrives tomorrow :D
Out of curiosity, because I can't remember, do you have vsync on or off for FreeSync? I recall G-Sync is best one way and FreeSync the other, but I can't remember which :(
You can apparently improve BLB with a hairdryer also, using it on the back of the monitor for a few minutes at a time. Not that I've tried this myself, but I've heard it works.
We do not know if it works, also we do not know of any implications that can come from it.
Also backlight bleed normally happens from over torquing, so why would a hair dryer move the panel.
I guess the premise is heat. As you know, metals expand and contract to temperature, and plastics become more malleable. I'd imagine it's along the lines of heat it up to allow the panel to settle more naturally - ie reducing the strain on it and thus BLB.
That's just my theory from thinking for a whole 2 seconds.
I know. It's sad really. I'm sure Acer will fix it with a future firmware anyway but it's hardly a major problem
Or is it..... a recall or self install. I know you hinted before its simple but knowing Acer they would probably advise a self install invalidates warranty.... ;)
This could also have a negative effect on the monitor.
The thing is, this is not a £100 monitor. This costs £980 and I would like to know how these problems did not get found during QC, also it is not exactly a small issue when half the monitor does not turn on after sleep, I might let them off if that was the only issue. The thing is it was not the only issue, we had the blue banding as well, this whole release seems to be ACER trying to rush it before ASUS (also other competitors) make their monitor.
It is a minor fault, not something that I'd return it for, or even be that bothered about tbh. But at this price point I wouldn't exactly be thrilled by it either. And calling people out as being sad for it? I dunno man, seems a bit harsh.
Well I would rather manufactures made a product that worked properly, you seem not to be too bothered, is pretty basic functionality too much to ask on 1 £1K monitor?
Another sign of poor QA
Was it mentioned in your review, don't see it in your "Cons" section.
