- 9 Jul 2013
Just in case anyone is after one the Jungle has spare batteries back in stock for £14.
I've had an occasional vibrating/rattling type sound coming from the earpiece. It sounds like the speaker is blown but the fact that it doesn't happen all the time debunks that theory.
Has anyone else had similar issues? Even though it is intermittent, should I just send it back to Amazon? What happens if when they test it it doesn't fault, does it matter? I've only had the phone 5/6 days...
Don't know if it's the same thing but sometimes on calls when listening to people the sound is really tinny , I suppose like a blown out speaker. After a while it can go back to normal or just stay like it.
Saying this it seems to be when I ring someone with a "Windows" phone. Wouldn't of thought that would be the course of it though.
have a look at sim only deals too as you can buy the G4 for £299 now sim free, may work out cheaper for you?
Ah, I've still got some months left with Vodafone, so would need to get one that I could plug my existing SIM in for at least the next few months before getting a cheap SIM-only deal. Where's the G4 at £299 from?
Really want to root my G4 and put a custom rom onto it but i don't want to loose VoLTE and 800Mhz access on Three.
I was gutted when I found out that the international sim free g4 doesn't support voLTE. Only the 3 handsets do.
How much of am improvement does it give mate?
Go to hotukdeals and search for g4. You will see![]()
