- 6 Jan 2013
- Rollergirl
I found the cut scenes a bit of a bore initially, but soon realised they were a major part of the game and written excellently. I never skip any.
I thought the pig herding was a nightmare.
It took me ages to get then herded as they just kept waking off to the side. Really annoying.
Bit late to the game, no pun , how do I complete the griffin quest? There's no marker on the map
Any tweaks I should be using. Or mods please? Running crossfire and glad to haven the flickering had gone after an AA tweak!
Dodging is your friend. Rely more on that than blocking. It'll set you up for an attack more often than not. Rolling shouldn't be used unless you're getting swarmed and need to get a bit of breathing room.Thanks glanza but ignore me. Talking through my balloon knot! Already killed it.
I can't get used to the combat at all... any tips? always seem to be killed, my block/counterattacking is shocking.
Edit: running the enhancedweather, immersive hud, ultra gore and weightmod.. yet to see any storms though! still only in the first town mind you.
Just regular attack button when you're near them.Thanks dude
Is there any button for one-shot kill / finishing move or is it automatic? Can't remember from the tutorial at the start of the game.
Anyone knows where I can get the Witcher 3+DLC cheaper than Steam? Looking for Steam codes only, no GOG. I found it on CJS-keys at a decent price but I have heard so many bad things about them..
Both for £53 at G2A - bit of a saving over the steam price.
Bethesda do great expansions, though.Completed the expansion today, just so so good
See Bethesda, that's how it's done!
