- 6 Dec 2013
- Nottingham
I tried the Hagerdoom hack at one point- although it didn't work for me on the original AOC driver. That's all I can say.
But this is the first I've seen about 'overides'. You may be correct, but I 'updated' the driver as described - and as it's 'supposed' to work.
I did, however, 'move' the previous drivers to try and ensure Windows couldn't use them regardless.
Have you tried my procedure (unticking 'compatible hardware' and making sure you've turned off digital signing in the reboot immediately before the install)?
I have to say things generally, at my end, seem rather inconsistent and unreliable - how much of it is specific to my hard- and software I can't say.
Windows 10 seems to be trying to update this morning - so I'm sure that'll Bork things if nothing else does!
I should add that what you say about the Windmill test bears out what I was saying last night about my 270 performance - I said I was getting the v-sync look down to 40fps - and, yep, the Windmill test (which I did again this morning) let's me choose 45fps.
Using the 'test signal' (which I find more useful than the windmill animation) things get more confusing really - with 'v-sync' on, the bar is pretty smooth (although not quite as good as using freesync with my 290), but clearly tears with v-sync off... which was not at all my experience in- game, as described.
The point being that I've got v-sync turned off in both the games I've mentioned ... 'you couldn't make it up' ... and, honestly, I'm not...
quite a mix-up!
As such, I think maybe I'm not helping in the general scheme of things - I'm seeing what I"m seeing, but none of it makes much sense.
I will re-install my 290 at some point today, and see how I get on with freesync off there too (in this case, actually turning it 'off' in catalyst control), I think...
after doing some reading, i believe the hack did work, but not on the first reboot and i believe it might still be in play(edid override can be applied, you can then update the driver and the edid override will still be active).
in order to test if this is the case, what you would need to do is, go into device manager and uninstall the monitor driver(checking the box to delete the driver to),
it should then reinstall an older driver(repeat the above)
and do this until it no longer finds any more drivers other than standard pnp monitor.
alternatively use the following guide: http://www.howtogeek.com/howto/windows-vista/remove-old-drivers-after-upgrading-to-new-hardware/
clear the driver store using this:https://driverstoreexplorer.codeplex.com/
click 'enumerate'
sort by name and only select 'aoc' entry's for your monitor. touching other drivers could mess up your system.
select 'force deletion' and click 'delete package'.
once done, restart your machine. now restart again disabling driver signing with the usual f7 method.
install the new driver in the way that you mentioned earlier.
reboot normally twice.
try the windmill demo and see what options it gives you.
the above could also explain why your gpu and monitor are acting oddly.
