How do you set up supply lines?
Also, I can't seem to fathom a better way to see what/who is assigned to which resources:
Yes if the NPCs are actually farming the food you can hover over them and it highlights which crops they are assigned to, but if they walk off to another area of the settlement (Which they seem to do A LOT), then you can't tell. Anyway to get this info?
My Sanctuary seems to be bugged too; I have enough water, defence, beds and so forth and happiness will climb when I am there. But as soon as I fast travel away and check the settlement in my PipBoy, it tells me I have less settlers and not enough resource? Wtf?
easiest way is to build a bell that summons them then they are all in one place
supply lines are set in build mode..you just wander up to a person and press R1 it will then open a list of other settlements and you chose which one to send them to, then confirm it
it doesnt share everything though, as far as I can tell its only really building materials for the base, any guns, armour and junk used for modding are not shared
so gears, wood and steel are shared..but screws and adhesive , for example, are not
