Assassin's Creed Syndicate thread.
Finally downloaded go to play the game and..........crash ACS has stopped working cant even get into the game it just crashes on the loading part.
EDIT: Found out the problem was actually windows 10 and the stupid bug with memory staying at over 90% usage
Runs fine for me @ 1440p with my 980ti not sure what fps I'm getting as can't get rivatuner to show up ingame for some reason but it runs smooth no stuttering or huge drops in fps from what I can tell.
So you're getting 30 cinematic fps.
No, as I said you just need to choose the correct settings for your spec pc. I literally turned down the shadows and hbao, they look insane at ultra. Just because something pushes boundaries does not mean it runs bad.
980Ti needs to drop settings at 1080p? You're kidding me, right?
Top Gear's ended, so James May's now spending time on hardware forums hating on random games:p He's done with Fallout, now he's set his sights on Syndicate:p
Reality check mate, there are more than a few games in which you have to turn down certain settings even on a 980Ti at 1080p. Stop making a fool out of yourself and maybe fire up your favourite game or read a book instead of forcing your opinion onto people and telling them how the game runs for them.
Top Gear may have ended, but theres another, new, better one, coming soon.
I bet you said the same thing about Unity.
Its another poorly optimized Oobi title.
should not have drop any settings on a 980ti @ 1080p lol
Try GTA V with ultra grass and all the additional goodies then:p Or Witcher 3 or Crysis 3 or etc. etc.:p Besides, it all depends on your definition of maxed. If you think you won't have to drop ANY settings on a 980Ti then no chance in hell.
EDIT: Here;p
Surprising, innit? And he's not even maxing the advanced settings. MSAA probably kills it, though. However, I'm sure than even with it at x2 he wouldn't get perfect 60fps.
There doesn't appear to have been any comments on this game for a while, does that mean everyone is too busy playing to comment
Yes, currently mastering the art of running multi take downs & quick escapes with the grapple :p
