thats what i have![]()
According to the fella in the video, disable MFAA in nvcp should fix it...
Runs bad like Unity.
I have amd on my lappy![]()
It does not run bad on my pc. Just needed to dial down some extreme settings. Ultra really is ultra.
Hence why it runs bad.
Uplay has a built in fps counter in the settingsRuns fine for me @ 1440p with my 980ti not sure what fps I'm getting as can't get rivatuner to show up ingame for some reason but it runs smooth no stuttering or huge drops in fps from what I can tell.
So you're getting 30 cinematic fps.Runs fine for me @ 1440p with my 980ti not sure what fps I'm getting as can't get rivatuner to show up ingame for some reason but it runs smooth no stuttering or huge drops in fps from what I can tell.
No, as I said you just need to choose the correct settings for your spec pc. I literally turned down the shadows and hbao, they look insane at ultra. Just because something pushes boundaries does not mean it runs bad.
Top Gear's ended, so James May's now spending time on hardware forums hating on random gamesHe's done with Fallout, now he's set his sights on Syndicate
Reality check mate, there are more than a few games in which you have to turn down certain settings even on a 980Ti at 1080p. Stop making a fool out of yourself and maybe fire up your favourite game or read a book instead of forcing your opinion onto people and telling them how the game runs for them.
Top Gear may have ended, but theres another, new, better one, coming soon.
I bet you said the same thing about Unity.
Its another poorly optimized Oobi title.
should not have drop any settings on a 980ti @ 1080p lol
Seriously embarrassing.So you're getting 30 cinematic fps.
980Ti needs to drop settings at 1080p? You're kidding me, right?
There doesn't appear to have been any comments on this game for a while, does that mean everyone is too busy playing to comment
