Can anyone recommend a headset for the Xbox One?
It should only plug into the handset, so no wires going across the room to the console.
At least it needs to be a mic + allow you to hear friends, but ideally allow you to also hear all audio too, which I think the XBox One can do now?
ie: These? - http://www.xbox.com/en-GB/xbox-one/accessories/headsets/stereo-headset#fbid=zQsz_mxGdx3
I got these from the "used" part, nothing wrong and like brand new and fulfilled by Amazon.
They come with the adaptor, you can mix the game sound and the mic right on the pad, how loud the sounds are over chats, and overall volume of each, very very happy with them.
They plug into the controller, so not other cable other than that.
http://www.amazon.co.uk/gp/offer-listing/B00D96BMV8/ref=dp_olp_used?ie=UTF8&condition=used
I can see the Turtle Beach Ear Force XO on there for £29.99?
Wasn't sure whether to create a new thread or not but anyone use or used kontrolfreeks? There are too many choices to pick from. I've no idea if I want really tall ones or ones where one stick will be higher than the other. I don't know anywhere I can test them beforehand either so I order right ones.
I've noticed that since the Dashboard update that I no longer receive achievement notifications on screen once unlocked. They are unlocking that they appear in my notification bar.
Anybody got advice?
They're really for high performance players or if you feel the controller is desperately uncomfortable from the height / feel of your stick (giggity). I've played with a variety and overall I couldn't confidently say they improved my aim/play at all... But others may disagree! I didn't have the patience to scientifically test the performance gain.
You tried restarting the Xbox from settings / notification bar (assuming you have yours on Always On mode?)
I've not got that issue since joining the Preview.
Anybody got advice?
So this is looking very interesting!
That does look interesting and I don't know why but I am really looking forward to the release of hololens more than any of the other VR type glasses.
