Just Arrived! VSonic VSD3S
here's a pic of one of the pieces in the ear, problem is that although it looks secure, it feels loose and drops out after a bit.
Okay dokay. Well, you have the right idea/placement. If that doesn't feel secure then I would be inclined to say you might have bad insertion depth - try a different tip, see if that helps.
use a larger size tip.
it's the seal created by the tip that holds them in your ear, the outer body has nothing to do with it.
can't use a larger tip as they don't fit into the ear canel well enough to secure them, that's why i had to go with the small tips :(
Try the foam tips? Give them a good roll between your fingers, insert them (be quick about it, so they dont expand before getting into your ear canal) and then let them expand. Should be the most secure of fits.
Just ordered a set. Hoping there worth the punt. Just can't seem to find a set of in ear monitors I get on with. I bought a set of klipsh x10 and was so unimpressed by them. Also tried a set of senhiser in ear that were around £60 , again unimpressed . I was all set to order a set of shire 425 until I saw this thread ,hoping this will save me a few pennies :p
managed to get hold of a set, works fine with the right ear, left ear is still giving me a bit of trouble though.
seems that the more i move the cable wiggle is causing issues with the left piece, while the right one is fine.
had to work the lead so the small piece of plastic on it has the wires going to the headphones fitting me like a sodding chin strap, its helping but i'm still not 100% happy.
looking for a decent variety pack of the foam tips, ones i got at the moment are small, so hoping medium/large will solve the problems with the left ear, fingers crossed......
It's common for people to have different sized and shaped ear canals and I'm surprised it doesn't come up more often.
never come across it before, i usually have no problem or problems with both sides, usually to do with the cable tugging.
tried the over the ear grips before and they were to uncomfy, also had in-ear pieces that hold in position and those worked fine without any discomfort.
i'm hoping this will solve it as the sound from them when their located properly is brilliant.
Ordered a pair, despite me having some SoundMagic PL30's and JLab Epic Bluetooth's that I've only just imported from the US and cost me about £90 all in. They had better be good, Cookeh!
Fantastic. Will see what the supplied ones are like and go from there.
Listening to them now, these will definitely do a job of blocking out some engine noise I think. The foam tips are good.
At first I thought I had an issue with one of the buds being louder than the other, but I think I just had one of them pushed too far in to my ear. They fit my ears perfect and I have pretty flat ears, the casing slots in nice.
Now to update my Spotify with music that makes the most of them :D (Any recommendations?)
manage to sort some tips out that seem to be working (called triple flange), had a quick go with them and going ok so far.
feel across a little tweak that helped with the wire being looped passed by the ear pieces on my glasses, but don't want to take the chance that the pressure (even though its not much) will damage the wire :(.
Black Friday sale at LMUE
Highlights
25% OFF FLC8S- NOW: SGD 348 (WAS: SGD 465) Back by popular demand! While Stock lasts!
VSONIC GR07 CLASSIC: NOW : SGD 105 (was SGD 125)
VSONIC GR07 BASS: NOW : SGD 105 (was SGD 125)
ALPHA & DELTA AD01: NOW SGD 117 (was SGD 130)
VSONIC VSD3 GREEN, GREY, RED-BLUE: NOW SGD 48 (was SGD 68)
VSONIC VSD3S GREEN: NOW SGD 48 (was SGD 68)
VSD3S/VSD3 PINK: NOW SGD 45 ( was SGD 68)
DUNU DN-2000J: NOW SGD 399 (was SGD 470)
DUNU DN-2000: NOW SGD 340 ( was SGD 396)
DUNU DN-1000: NOW SGD 220 ( was SGD 261)
OTHER DISCOUNTS
ALPHA & DELTA
ALPHA & DELTA AD01 with upgrade cable: NOW SGD 140 (was SGD 150)
VSONIC
GR07 BASS: NOW : SGD 145 (was SGD 163)
GR02 BASS: NOW SGD 32 (was SGD 42)
VSD2S: NOW SGD 39 (was SGD 50)
VSD5: NOW SGD 75 (was SGD 90)
DUNU
ALPHA 1: NOW SGD 195.50 (was SGD 230)
TITAN 1: NOW SGD 155 (was SGD 180)
TITAN 1ES: NOW SGD 70 (was SGD 79)
TITAN 5: NOW SGD 180 (was SGD 195)
DN-12: NOW SGD 30 (was SGD 42)
HAVI
HAVI B3 PRO 1: NOW SGD 66 (was SGD 78)
HAVI B3 PRO 2: NOW SGD 66 (was SGD 78)
FIDUE
A71: NOW SGD 110 (was SGD 128)
A73: NOW SGD 170 (was SGD 203)
A65: NOW SGD 69.70 (was SGD 85)
FUTURESONIC
FUTURESONIC G10: NOW SGD 279 (was SGD 310)
SHANLING
15% OFF SHANLING H1- NOW: SGD 170.85 (was SGD 201)
15% OFF SHANLING H3- NOW: SGD 376.55 (was SGD 443)
15% OFF SHANLING M3- NOW: SGD 458.15 (was SGD 539)
SHANLING M2: NOW SGD 345 (was SGD 360)
SHANLING M2 Leather Sheath: NOW SGD 35 (was SGD 50)
GR07 BE for 105 SGD..... I... I... I have no words. Great price on what is, imo, the best earphone in the neutral/slightly warm category u to £150.
