always the same on mom or imenu I have 48/146hz
edit : which cable you use? Dual-DVI or DP
Got this monitor today, fortunately it's the revised one without the Overdrive bug. The driver also works, but the display flickers when the framerate is 30. Is this the reason they are going with 35-144 Hz?
The colors are, well, if you are used to a good IPS panel pretty bad but overall, I enjoy playing games on it so I will not complain about it too much.
[81859] Flickering may be experienced on some monitors when AMD Freesync™ is enabled
Hmm so it's "normal"? Because I don't think the WHQL driver will fix this.
Other than the flickering, I like the monitor. Games really look great on it and with Freesync enabled gameplay is so smooth even at < 60 fps.
Edit:
I don't think I see the flickering in the AMD Freesync demo utility. Maybe the Crimson driver is a little bit bugged? Since the release notes state:
I have an R9 380 and when I disable Freesync the flickering is definitely gone. It only flickers within the Freesync range, at lower framerates. I also tried Catalyst 15.7 and 15.11 and it flickers the same. The flickering is the worst in the intro video of Just Cause 3, but the Crimson release notes make note of flickering in the JC3 intro and menu's, so maybe that's to be expected. The Windmill demo however does not flicker here.
I found an interesting article, it's about G-Sync flickering but the symptoms are exactly the same in my case.
http://www.pcper.com/reviews/Editorial/Look-Reported-G-Sync-Display-Flickering
A certified DisplayPort cable is on the way, I will try that. But I don't think it's a defect.
After some further testing, it's not tied to framerate at all as I thought ealier. I've been playing more games yesterday and it just flickers at random moments.
