- 9 Apr 2012
You can still jailbreak it and customise... no huge difference from Android there... you have to root the phone for the main customisation options.
Not true. You can customise most of Android without root.
I would take the inherent security and ongoing support of iOS over the possibility of having different coloured icons.
Me too... I jailbroke my iphone 3g to try it... ended up putting it back to standard... again for my 4, just because I wanted to play with it... but again put it back to standard pretty sharpish.
Haven't wasted my time again since... I couldn't really care less about coloured icons vs stability and what I use my phone for, all default apps/options are well suited to it.
If your on M you get pretty much the same security as iOS, granted its on a small subset of Android devices. Android is pretty much as secure as iOS, most of the crap is just apps that want extra permissions or you need to root your device, install a dodge 3rd party App store then you have a chance of getting any real virus. Which isn't too difference too the experience on iOS where you can get virus from those Chinese app stores people use too pirate apps once they jailbreak.
There are security issues in iOS that have been there for months.
It won't be a new phone technically. It will be refurbished.
It's practically new. The replacement phones are units that failed QC and needed to be looked at in production. This usually involves a unit that got damaged and thus had a new casing put on or reported a hardware issue on final testing so needs a part replaced.
I always thought it was devices which customers returned or were faulty and then have been returned to brand new condition.
Could be either, tbh though it all looks brand new I had my iPhone 6 replaced and it was just as good as BINB. Sometimes its better cause IIRC they go through more QA.
