- 26 Aug 2004
- South Wales
I was getting flashbacks of the old Twisted Humour flash cartoons for a moment there
I was getting some flashbacks of the old Twisted Humour flash cartoons for a moment there![]()
I was getting flashbacks of the old Twisted Humour flash cartoons for a moment there![]()
Hmm, I seem to be getting flash backs as well![]()
I would remove that Gif or you will probably be going on Holiday sooner than you think
So.... all this about AMD having a 6 month lead... or that the first Polaris cards could be out in two months. Doesn't look likely, does it.
This isn't the first time they've said "back to school 2016". A much, much earlier article was doing the rounds last year, pointing to the same release window.
So unless nV aren't releasing until 2017, it's going to be close. Ultimately it doesn't matter if AMD have had working silicon for months now, if they choose not to release until August/September, they aren't going to beat nV to the market.
But then, AMD always seem to manage to snatch defeat from the jaws of victory.
VR is a must for me now and that overrides all of this Free/G-Sync business, so not fussed if I lose G-Sync in truth.
Fair enough, not really relevant to my quote you used though which I'll reiterate-FreeSync panels use open source tech and only vendors can choose to support them or not, no one is locked out from using it but it isn't the end of the world if you choose to jump in to a vendor open/closed tech anyway as you are missing out on vrr(but can understand those that don't want to).
Mine are all genuine and 99% of them arguing why Nvidia is better than AMD (which it is)![]()
Cop out-I didn't say FS was open source, I said the panels were, the guy that quotes year old threads swinging it 'Stalker' the horror.![]()
And you finally grasped that Freesync isn't an Open Source/Open Standard but Adaptive sync is an Open Standard. Freesync is AMD's tech for use with Adaptive Sync panels
/end
I thought it was fairly clear that Freesync monitors are Adaptive Sync panels that are open so any gpu manufacturer can make their cards work with them.
Freesync is essentially the name of the drivers coded by AMD for their own gpu's. These will not be open to any rivals since that would reveal how AMD codes their gpu drivers.
