I can assure you that Elite Dangerous on my XR341 is glorious, especially with the FOV increased![]()
What FOV to use on 3 x X34 ?
Ive got mine overclocked to 100hz and its been fine but Ive just been sat watching youtube in a window on the desktop and the screen went black for a second and came back on with the DP sign in the middle like its been disconnected. Anyone know if this is just the result of the overclock being too high maybe or a bigger problem? Ive knocked the OC down to 90hz and see what happens but this is the first time its happened in 3 weeks and its been OC'd to 100hz the whole time
ive recently encountered an issue where no input is detected. When its turned on at source, the display does not pick it up unless i unplug and replug it. Can't find this issue mentioned much online, any ideas?
It COULD be the cable... if you have another, swap it and see if that helps. The problem here is no-one really knows what running a monitor with a 66% overclock 24/7 will do for the reliability and longevity of it. We're in somewhat uncharted waters with the X34 and upcoming Asus model (which uses the same panel). It's always been a concern of mine, but only time will tell.
Got delivery of my B grade X34 today and it is looking great. As Leon4112 has found, my monitor flickers when set to 100hz, but is totally stable at 95hz.
As the monitor was fully boxed and still wearing all of its packaging, manual bad still sealed, all cables, etc present, I reckon it was 'failed' by Acer for not hitting 100hz.
There are no dead pixels and, as far as I can tell, absolutely no BLB.
I'm a happy chappy with only the sound to sort.
I want to try out the built in speakers to see what quality they are. However, I can't seem to figure out ho to get sound through the DP cable from my 980Ti. Any suggestions?![]()
Re-install the Nvidia drivers mate. Perform a "clean" install and ensure the audio is ticked![]()
Snip
The technician taking care of my RMA told me they had received a message from Acer, stating that the backlight bleed issues in particular, will be sorted on the next batch of monitors arriving in feb/march. That should be comforting to know for people who've ordered the Asus PG348Q, because QC definitely IS the explanation for the late release.
Yeah I doubt it. BLB was an issue on the original LG UM95, and it was an issue on the Dell version of this panel as well. Just something you have to accept with bigger panel sizes I guess.
The one that's popped up on the bay, one of these two you got?
Just wondering as you don't mention in the listing that it'll be 3rd hand to whoever wins if it is yourself.
