Morning all
So, this turned up last week. Ordered Friday, was here on Tuesday.
Flavour great, really easy to build on, build quality is solid. Draw is quite tight but I like that. The only small niggle I have with it is that it does build up quite a lot of condensation in the chimney and the mouth piece, so it feels like it is flooded when it isn't. Still, a tiny downpuff sorts that out in short order.
Compared to other atties I have used (mini nautilus, subtank mini, youde bellus) the flavour is much, much more concentrated which I suspect is a result of the narrower airways. As a direct comparison with the Bellus, the flavour differences are somewhat akin to the differences between neat whisky (heron) and whisky with water/ice in it (bellus). More air means there is much more space around the flavour, if that makes any sense.
Is it worth £120? Definitely.
