No.Thanks, AiiR. Daft question perhaps, but moving from a 920 D0 to a Xeon 5650, will that require a reformat and reinstall of OS?
Cool, cheers. I think I'm gonna grab one just out of curiosity. My little 920 D0 has been sat at @4.0Ghz for the past few years and never missed a beat but this 6 core shenanigans is tempting me.
I'm running an Asus P6X58D-E, I take it that this mobo will be fine with a 6 core Xeon?
I'm using this exact board, no problem at all.
I might give one a pop then. I notice a seller currently on the Bay of 'E's' selling them for about £60 - he has 60 of them for sale!!
If no one beats me to it i'll post up some bios pics tonight as i run the Asus P6X58D-E. Running on the 'latest' bios which was from 2012 lol. Ran a 930 @ 4.2 before swapping to a x5650 again at 4.2 but it would run at 4.4 but happier running 24/7 at 4.2 again so backed off a little and the temps barely get hot compared to the i7.That's good to know. What BIOS are you running on it and have you over clocked it? If so, what settings have you tweaked in the BIOS to get to where it's sat?
	They were £50-60 when they first started appearing. Doesn't surprise me that they've gone up since the demand will have risen a bit. That said, I'm sure you can find one for less if you are willing to wait.Nice. Made a 'Best Offer' to a seller on eBay of £55, but he's sticking at £65 (+£3.40 P&P) for an X5650. Is that a bit pricey, going by what some of you guys said you managed to pick one up for?
It contains raid drivers hence the size, you don't need to install them though.Cheers dude, that would be good. I'm running the 0303 BIOS from 2010 apparently. Had a quick look at the Asus support page for the board, does anyone know why most of the BIOS updates are around 1.04Mb but the latest one at the top shows its 247Mb? Seems a bit of a strange difference in size?
.Not sure what you mean by Flex mode but I'll be converting from 6 GB triple channel to 16 GB dual channel tomorrow. I don't anticipate any issues...Yeah, I'm in no rush so I'll hang fire a wee bit. Do these Xeons play nice with 16Gb of RAM running in Flex mode on the Asus boards?
Also works with 5 sticks too altho never heard it called 'flex' mode before!Check THIS THREAD I started a ages ago on the subject, most X58 based systems can run in 'Flex Mode' with 4 sticks of RAM fitted which gives you Triple Channel mode as normal for the first three sticks and the 4th stick runs in a type of single channel mode. There are images in the above thread describing it and what slots the RAM sticks need to go in.
Do we know if a Rampage 2 extreme supports the xeons?
