Ohms law battery safety goes out of the window (Within certain reason) when using s regulated mod. Worst case scenario on a dual battery mod at 113w is just under 18a regardless of resistance (Amp draw will increase as battery voltage drops)
I see, So once the regulated mod limits the AMP's the only benefit of increasing Wattage is the Voltage increasing?
Just that I'm currently vaping a 0.24ohm single coil stapled clapton and was wanting to go dual but was concerned due to the power requirements.
As I do understand Ohms law and battery safety to a degree but I get slightly confused as like you say, (Battery safety goes out of the window within reason) on regulated mods etc but when I do the calculations the numbers feel wrong.
How safe is the 0.11Ohm build at 113W, When you say once voltage starts to drop the amps increase does that mean the batteries shouldn't be run down or is that when the "Low power" warning kicks in due to being regulated?
Sorry for the idiot proof queries.
FlavourArt do a couple of different additives for reducing harshness
Anything I can add to take the harsh edge off of ecto cooler? Mixed up 100ml, had a tanks worth, so 3ml or so and just find it quite harsh, almost like vaping neat orange juice![]()
Finding it difficult to find somewhere that has Herakles Plus coils in stock, can anyone recommend a UK online store?
Leave it for a week or so and it should settle down.
It's already over 3 weeks old, mixed it up and forgot about it![]()
Have you let it breath?
Literally just shake it up, then take the cap off and leave it in a cupboard for 24hr
Aside from Kanger, and the Uwell Crown... what other tanks are people recommending? I need something with decent stock coils, as building my own just isnt for me.
Sigh.
Dunno what it is with me and leaky tanks but I'm about to toss out my Uwell Crown. The thing has developed a leak like you've never seen. Absolutely ****ing juice out of the airflow, I've done some googling and there were a couple of reddit threads dedicated to the issue - I've tried everything suggested there and its still doing it. I've tried new coils, tried the O-rings... I've done everything and I've wasted 20ml of juice today with no success - I'm not happy!
Sigh.
So I stick in a pair of brand new freshly charged HE4's, run fine, just stick them through the usual cycle. I've just put them on charge and one cell is all the way down at 2.35v while the other is at 3.3v.
