- 9 Apr 2012
My power button has started playing up/sticking, sometimes it's benign and just brings up the "Power Off" option instead of turning the screen off, other times it forcibly powers down the phone and keeps doing so (interrupting boot) until I manage to fix it.
Anyone else had this issue, seems like it was/is a common-ish problem, looks replaceable but anyone done that and if so where did you get the switch from?
Nexus 5 still doing fine but I have old 5.1.1 rom.
Whats the recommended rom people are using now?
Can anyone recommend a supplier of good quality (original?) batteries for the Nexus 5? I've had mine since launch and with around 1000 cycles by now the battery is probably on its last legs.
Just download the latest Marshmallow image, or do the OTA update![]()
Does anyone or has anyone repaired the USB socket on their Nexus 5 ? Mine has gotten really loose, the plug literally falls out the phone or sometimes it just doesn't charge at all. Going to miss my Nexus 5 if does die completely as I can't find anything out there spec wise that comes close to it.
