The SJ4000 is as good in terms of video quality IMHO.
Boring video for sample.
Hi, can you link me to the mount you're using?
I have an SJ4000, I might as well put it to use!
Cheers
Cheers
The early ones had a few issues but the 0805/0806 are known to be pretty solid. Certainly, aside from me having to tweak the connectors on the base, my 0805 has been rock solid.My reasoning for not using the 08xx series are
1 – Reliability, even in this thread alone there are a few users whose unit were faulty, look at Amazon have the same, look on YouTube, one of the main reviewer's unit turned up DOA. This alone put me off totally.
And that is not "huge", yes it is bigger than the 08xx but huge is an exaggeration.
Why is it so hard for you to admit that you are wrong? How many threads have to be littered with pointless arguing because you can't just back down? No, you just have to argue against the obvious.
After looking at the Git1 I for sure want one where I don't have to buy extras (suction cups)
Mrk - what unit do you use? From previous posts your cam seems very good
Anyone tried this dashcam? Have the option to pick it up for £90 on the weekend. Seems like its got the basics covered as well as parking mode etc
Out of sight, out of mind.
I've got the 200, friend has the 220, seems good enough
My 200 works for what I need it to do, record. I would take measurement of the size, it's not 'large' but if in the wrong place it can feel not small![]()
Cheers, I could get the 200 too but this seems pretty good for the price! Will check it out and report back
The thing is that Transend or any of the Nextbase offerings are no smaller than any of the action cam, why are there so much opposition in using something like a Git1?
But yes, they are 'larger' than a GoPro tecnically in terms of overall diameter3.9 out of 5 stars 1,987 Reviews
E-PRANCE® New G1W Novatek 2.7" Car Dashcamera Driving Recorder + 1920*1080P 30FPS + G-sensor + Car License Plate + MOV + 140 Degree Wide Angle Lens + Night Vision + H.264 Color Black
This seems to be top of Amazon anyone have this?
