- 1 May 2013
- M28
Whats happening on the 17th?
well on my calendar I have to put out my pink and black lidded 'wheelie bins'.
I don't think the whole "clock for clock" thing really matters when it is looking like you will be able to get custom pre OC cards at 2.4ghz (if the rumours of the Gigabyte G1 being clocked at that are true)!
Pascal is clearly designed to run at very high clock speeds, where as to get anywhere near even the stock 1080 clock on a 980ti you will need LN2.
I hope this is true and pascal can OC crazy. It will likely mean 1070 will end up being better than the 980Ti in every way![]()
Pink? where you from?
I have black, blue and green
From the land beyond beyond , from the world passed hope and Fear.....
Zzzzzzzzzzzzzzzzzzz.
I thought you weren't gonna comment again until reviews are out?
Wish the 17th would hurry itself up!
My predictions:
1070 (OC) on par with 980 Ti reference.
1080 Founders > 980 Ti Reference by 25%
I don't believe that pascal is less efficient and slower clock for clock than maxwell either.
It is also irrelevant co aliens to clock because nvidia developed a brand new architecture that could reach higher clocks.
You pretty much have to mind design choice:
Do more work per clock cycle but having a longer critical path means slower clocks.
Do less work per clock but crank up the clock speeds.
Pascal is a move to the 2nd methodology. Pascal might have a lowr IPC, but it does have fewer cores anyway, but it has been design to achive mcuh higher clocks. As a consumer the only thing you care about is performance,e not how it is achived.
Brother wants to order a 1080, When do they become available for preorder.
Obviously, but I was comparing 980 vs 980Ti here to put into context gain percentages.I don't think the whole "clock for clock" thing really matters when it is looking like you will be able to get custom pre OC cards at 2.4ghz (if the rumours of the Gigabyte G1 being clocked at that are true)!
That may be, but it's not exactly a massive difference to my example. Would mean a final score of 156 vs 170, which isn't as impressive, but not worlds apart.Also, stock vs stock a 980 Ti is ~30% faster than a 980. Not 40%
NVIDIA GeForce GTX 1080 also brings new technology called Fast Sync. We can’t give you any details right now, but judging from the graphs, this technology allows much faster frame rendering (30-40ms) compared to Vsync (90-110 ms). My understanding is that this technology is trying to bring better user experience in VR by replacing VSync.
