Was there a rip in it?
Result you got it back though a.Got the YZ125 back!
She's in a sorry state, they removed anything that was good and unique and replaced it with crap (bars) but she's home and she runs. Full bike wide rebuild is in order.
Adjusted the chain. Had to borrow a 27mm socket as I don't have one...
For me tuther day it was the plug spanner for the Honda XR as access is restricted by the shape of the head & the gap between the head & the tank so a real specific plug spanner is needed. I have a lifetime of tools & untold different plug sockets/spanners but of course I didn't have one that would fit the Honda. In the end I managed to do it with an old Triumph tool kit I have had laying around for long enough for it to go rusty. Did the job but ****** typical.How many wires does the battery charger have? surely two also, one positive and one negative, should be the same I would think? wire the satnav straight to the battery, or you could get fancy and wire it into the ignition.
OK I'll get a crimper for it, the satnav is waterproof so I assume the cable would be too?
Any tips on wiring the satnav up to my bike? I thought it would be the same cable that you get when wiring a battery charger up but it's just 2 wires and I'm not sure how to do it.
He means it's 2 rat tails no fittings on the bare wire.
Get a crimper and crimp some ring terminals onto the end and wire it up to your battery as usual. Cost about a tenner for a cheap one and some fittings from Amazon or find a friendly local with one.
