Isn't this...like....technically....stealing? or something?
In my mind it's closer to getting your mobile phone unlocked.
NVidia screwing around with MSRP and struggling to produce enough chips. And AMDs smoke and mirrors with this memory thing and the power usage thing. Both seem to be as bad as each other
Bring back the s3 savage and voodoo cards!Is suspect this whole thing was so they could stand on stage and say "... for under $200!" then they stop supplying the 4gb and it turns out there never was a 4gb version, just an 8gb with a different bios.
I think its time we get a 3rd GPU manufacturerNVidia screwing around with MSRP and struggling to produce enough chips. And AMDs smoke and mirrors with this memory thing and the power usage thing. Both seem to be as bad as each other
There's always Qualcomm and their ARM chips![]()
I like my graphics cards like I like my women, discrete
hahaha this.
Why supply it with more VRAM in the first place.
Surely they must have known people would find the extra memory.
That's tragic really, The drivers should be out before the card so it releases stable, AMD pls
Is there a way to tell without taking the cooler off?
you missed the ATI 9500non pro unlock to 9700. Nvidia did have the 6800le to 6800gt unlock, but thats the only one i remember.
this is the first time i've known either company to lock memory , probably just did it to test two price points.
Opened my VBIOS in hex editor and where his showed 8GB and 4GB mine only shows 4GB and 4GB.
The 4G version will have 8 Ram chips. If AMD could simply leave 4 chips off, they likely would have done so. But they need 8 for the 256bit memory bus (8 * 32bit).Yes at least you can be fairly sure, firstly clock your memory to 2000mhz (2000 x 4 = 8000mhz), if it isn't completely stable at this clock then its not an 8gb card. Also you can count the ram modules from the bottom of the card if you don't have a back plate, one of the stickers won't void your warranty if it's removed, the other one will 'Void if damaged' leave this one on unless you aren't bothered about warrenty. You should be able to count at least 6 ram solder points once that sticker is off, which means more than 4 ram blocks.
