Man of Honour
- 29 Mar 2003
- Blurton
Are you using the hdmi extender
This. Plugging the extender in has worked for at lleast4 ppeople I know.
I've never a problem with kodi not showing on recent. Running a 4k version.
So with FireStarter blocked and the Recent Apps list being unreliable, what's the best way to get a Kodi shortcut either on the front page, or on a Home button shortcut like FireStarter did?
Perhaps need a factory reset and setting back up, I have 2 sticks, both running Kodi flawlessly.
Does anyone have wifi issues with a Fire stick? I grabbed one on Prime day but it cant hold a stable wifi connection, get connected with problems every few minutes. Either on 2g or 5g. Amazon have sent me a replacement to try but from googling, it seems lots of people have this issue so I don't hold much hope. Shame, as its a great little device.
I get a very weak signal on the 5ghz band but 2.4 seems to work okay. don't get a great connection speed though. My phone in a similar position has no issue picking up with 5ghz band
Use the new firestarter called appstarter and set it to open with 1 click of home where you can access everything
SexyGreyFox [Deceased];29828360 said:They run Kodi flawlessly, the icon won't appear in the main screen or recent apps.
Should I see kodi as an app on a new 4K tv ? Or do I need to do something ?
Edit I'm being a noob sorted it.
SexyGreyFox [Deceased];29833893 said:You need ADBFire, the Android ARM version of Kodi and then sideload it.
There is another way where you can install ES Explorer (I think) and then follow some instructions.
It's all on You Tube.
