- 5 Jun 2003
- sawley/ long eaton
I fitted a luggage rack to my husky today. The 701 has no official way of attaching stuff to the back, but a guy fabricates his own racks. He only produces them in small batches, so I snapped one up recently.
I had to drill the fairings, so was a bit nervous, but it all ended up ok
Yeah, I got out dragged by a 125 the other day ;p
It's a needs a valve service which is about £500, new brake pads and want to maybe get it painted and fit a Brembo 19RCS, get the exhaust shortened and a few other bits![]()
Rode home at lunch and the bike started losing power... As the speedo is not working I throught it must be eletrical. I turned off the lights to see if that makes a difference and the power is back...and the speedo! Turn lights back on again and everything is still fine.
Happy that it's all working again but now I'm worried I have more of an issue somewhere. Loss of readings on the instrument pannel seems to point a bad earth looking at some CBR forum posts.....sigh
Rectifier
Had my R6 put back to her standard height. The guy i bought it off before was vertically challenged so switched out the dog bones. Wanted it put to it's normal height before i get the suspension sorted out for myself.
It may be a placebo but it felt like it was much more responsive and around corners it just wanted to lean in. Probably a placebo though
