Probably more than enough to clock 2 of them and a cpu![]()
Yes definitely
Yeah... a 750 will be more than enough for 1 card ... with both card and cpu overclocked.
2 is pushing it a little but could well manage it
Have a look at the EVGA ones, maybe they will fit.
I have the v2 bridge and a HB one from EVGA on pre-order. The V2 looks exactly the same size wise and fits just fine with the EK blocks.
I think the only reason the NV one doesn't fit is because of the bits sticking out the side.
I think I ordered the wrong evga hb bridge... 4 pci spaces between cards is correct, but they don't count the hidden one or the one the second gpu is in... So I actually need the 2 space one... Darn
Yup... checked and it was off. Thankfully I've been able to cancel the order... but now I have to wait for them to get stock of the right one
I thought I would run a little test for anyone curious re: flex bridge vs 2x flex bridge vs hb bridge.
My hb bridge score won't come until the component arrives though.
Here is the result with a single flex bridge:
http://www.3dmark.com/3dm/14066174?
14530
And here is the exact same setup / clockspeeds with 2x flex bridge:
http://www.3dmark.com/3dm/14066758?
16382
That's a large performance improvement. I also noticed noticeably less micro-stuttering with 2x flex bridge... in fact, I couldn't notice any at all... which is the first time since the GTX 690 I've not been able to notice micro-stuttering with an SLI setup... very happy with that alone
It looks like my results mirror the review that checked it too as I'm pretty sure Kaap's score is with the HB bridge... so it appears as though 2x flex bridge perform similarly to 1x hb bridge... it just doesn't look as pretty![]()
14530
16382
That's really good news Crinkle. I'm not in such a rush to find an HB bridge now although once they're more readily available I'm sure I'll get one if nothing more than to make everything look prettier like you say!
Nice, glad you finally nabbed one!!Ok so I finally managed to order one despite all the hassle with Digital River...
I gotta question for you guys.
I'm moving from water-cooled and overclocked GTX 980 Ti SLI to a water-cooled overclocked Titan X (Pascal) as I don't want to be depending on multi GPU support any more. They should be more or less the same in terms of fps when SLI is well supported vs the Titan XP. I was thinking of keeping a single 980 Ti to use as a dedicated Physx / Gameworks card. Am I crazy?
I game @1440p 144Hz G-Sync right now and am not 100% convinced that the Titan XP is the single 4K GPU messiah card, how do you guys (who already have the card) feel about its 4k performance?
Looking around at some of the reviews, I see some low'ish numbers on games like Witcher 3, The Division and even Batman Arkham Knight at 4K - that's kind of why I was thinking about a dedicated Physx / Gameworks card. Would it help the fps at 4K in those titles?
I'm not buying a second Titan XP - until mGPU support really improves, I'm done with it. Been using a mGPU rig for almost 9 years now and support isn't what it used to be plus 4K monitors only go up to 60Hz right now and a second Titan XP just seems like a waste of money for those missing 10fps - 15 fps on those demanding titles to bring it up to a solid 60fps.
I'd really like to move to 4K (G-Sync) but I'm not sure I could live with 40fps on games I love like Witcher 3.
As for your question. I've been running Titan XP SLI and I would say for some current demanding titles yes you do need both cards to fully max them at 4k.
GTA 5 runs very well with these (but only just), completely maxed out, all settings on except for AA. My game is also heavily modded. Stays at a solid 60fps 90% of the time, but I do get the occasional drop into the mid 40s, made bearable by G-Sync. One card would not cut it for me in that game.
However Hitman (2016) seems to run damn good in DX12, single card. In fact it's smoother for me than with SLI in DX11. So I'm able to max that game at 4k (with SMAA) and achieve 50-60 no problem.
Btw this is with an OC of 1950/10400.
