- 9 Jul 2013
So is this the X8? Seems pretty decent picture quality.
still looking, really want one.
is there any which are light weight, can easily be put in a standard rucksack and not fill it all up, still gnat room for like coat, food and water bladder in there. uses phone as screen for fpv, can handle wind and generally isnt poop. flying time not to much of an issue and has return to land feature. preferably for around £200.
DJI Phantom Pilots here - what tablets are you using? I tried an iPad Mini 1st Gen but it was way too laggy video feed wise. I'm now looking at either an iPad Air 1 or iPad Mini 2, both cellular. Anyone using one? Currently using a Tesco Hudl 2 which is actually pretty good but I'm fancying an Apple tablet as I kinda prefer the DJI Go app on iOS rather than Android.
Curveball possibility is the Nvidia Shield K1, supposed to be pretty good also. My budget is @£200 so I'm firmly in the 'pre-owned' market.![]()
Mmmmmmm a phantom isn't heavy...What are you wanting to DO?
Something like a Parrot (Be bop maybe?) might run off your phone, I know they do some which you actually use your phone to fly it as well.
Anyone have a Spec Me list for a DIY drone that can accomodate a GoPro/clone?
Want to build one myself but all the spec list I've found doesn't say whether it can accommodate an action camera.
Take it out when hiking and capture some videos/pictures, saw this last night certainly small, no idea if it would be any good
http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=68596
That depends on all sorts, the weight of the quad compared to how much the quad can lift, the amount of thrust etc etc
So you are wanting to build one from scratch then?
That is just the frame mind, you need to buy the motors/escs etc etc.
And it's a tri copter, so no idea how it would effect smoothness of pictures/video.
Yup, I don't mind buying kits and adding my own electronics though
Saw a few kits/frames from HK and they're mainly 480mm/550mm sizes, sound about right?
yeah i realise that, all though would need help on the parts especially controller and flight computer.
open to other suggestion, just needs to fit in a standard rucksack with space for my other walking kit and be light enough to not bog me down to much. although if no other suggestions by payday in two weeks, ill probably just go with that.
Depends on the type of quad really but the sizes seem alright.
250/210/180 are more racing type generally. Have you ever built one before? It's not neccessarily a case of buy the parts, strap it to a frame and fly away.
