- 1 Oct 2007
- Hawkes Bay , NZ
What are the lead times on a new R? Are they generally available or are they join the que?
So has anyone on Mk7 golfs had the window switches just misbehave? When I press down usually don't the first few times, sometimes when they're partly down they'll stick or even go the wrong way! Every switch (even rears) seems affected and if you play a lot with a window it starts working ok. It's really annoying, I reset the switches but it doesn't do anything. Took it once to a dealer for another thing and mentioned it, they kind of fobbed me off telling me essentially I was confused by the half/full button, booked it in again for just that so hopefully they'll take a good look :/
But if it's common maybe it'll be easier to get them to take it seriously...
Is Sat Nav,heated seats and folding mirrors standard on all the mk7 R? (Not just year dependent)
The folding mirrors are , however the Sat Nav & Heated Seats (part of the Winter Pack) are only standard on MY17 R's i.e from build week 22 of 2016.
Well at least VW have finally seen sense by including the "normal" Sat Nav unit found in the GTI in the R. Took them long enough.
When I purchased my R I nearly laughed when the sales person explained that, for some bizarre reason, the R only has (had) the same media system as the base model...
A tad expensive, similar spec about 1000-2000 less.
I had mine on order for 3 months. Called for an update only to be told
"Not sure how to tell you this but your order has been cancelled"
No email or call thread to say where the request came from. After ranting for 5 mins I realised it was pointless. Car was gone, would have to get a standard one or join the queue again.
Got my deposit back and went an ordered a new 135i instead. Will be here in 2 weeks.
