- 23 Feb 2009
- South Wirral
And sort of on the topic of Jags in TV shows, I spotted this earlier: Boycie's Jaguar from Only Fools and Horses sells for £115,800.
I have a few questions, sorry to hijack the thread but calling on your experiences....
I had nothing but problems with my early XF
Anyway, check all the electrics, tyre monitors, warning lights, remote locking etc etc
Check the boot for water/dampness, the seals go on the back lights and the boot fills up, not good for all the electric guff in there
Wheels can crack, tracking etc can be quite easily ruined, so check that too.
Personally I wouldn't buy another early XF again
I'm sure others have been fine![]()
Im looking at a 2008-2009 XF Luxury 2.7D...after ive driven my fiancee's uncles...fantastic car and fell in love a bit.
A few questions if i may:
Whats the mpg around town and urban? Ive been on honestjohn and theyve said around 35mpg on a mix...92% of whats claimed by manufacturer.
The uncle reckons more like 45 around town and 55 on a run...im sceptical.
Main point is...what kind of problems/areas should i look at on these cars and are they renowned as having any faults?
Lastly what kind of mileage for that age do you feels acceptable...the example he bought was as follows:
2008 Luxury, 130k, £5k from Sterling Cars...but it has a gearbox problem (needs a new one) and he believes wishbone issues...so overall £1.5k of work - £6.5k hes paid.
My budget is around £8-9.5k...im looking for the best economy and performance i can get.
Thanks in advance for your help![]()
Oh and a baby due any minute and a need to replace my partners Corsa with something more adequate (thinking Golf, Leon, Altea)...so busy times, but exciting all the same.Torch [P4];30025784 said:yep the 2.7d is a bit long in the tooth, I have the S type 2.7d and mpgz are about 28mpg round town to 34mpg on a run. I have mine mapped to around 265Bhp which gets rid of the lag
id start looking at the 3.0d portfolio if you can![]()
I give up! **** that car. Any dealer will deal with it under an official Jaguar warranty, don't expect them to be massively better thoughQuick question, if I was to go to another dealership as long as it was Jaguar, will they work on my car if it's under warranty?
I've had a few issues with my cars which have meant me doing a tour of local dealers until I find one who actually finds the issue, or agrees that it's a problem, or agrees that it's warranty work etc..
My advice is to just keep on at them if you can be bothered, they'll normally eventually give you some credit to spend in a dealer as compensation for their incompetence
