Go to the MS store, press the little icon that looks like a person (next to the search bar) and you'll see the redeem code option.
Why do you have to pay a extra tennner for the PC/box1 version??
https://www.amazon.co.uk/Gears-War-...863589&sr=1-1&keywords=gears+of+war+4+pc&th=1
I tried that but got the error message saying to try later was really wanting to get it preloaded. Will give it another go in a bit
Just another way of screwing money out of you, but if you were a PC and XB1 owner and wanted to play on both platforms with your mates or whatever then its actually a good deal as both 'versions' are effectively £25.
Basically 1 code that works for PC and XB1.
Type wsreset into the search box on the toolbar and run the prompt, that will reset the windows store cache and will allow you to download the game. I had the same problem. It may take a couple of goes.
Hope this helps.
OK if I buy this can I give the code to my friend so he can play on Xbox1? TIA
^ You should see the videos of him with Kevin Hart, so funny.
Also just snagged this from cdkeys, so can't wait to play.
I agree but for most players the game is free if you bought a GTX 1070\80 like I did recently so I cannot say anything.Prices are disgusting. 50 quid for the base game but because you didn't pay 80 quid we're gonna make you sit and wait while the 80 quidders play it first.
What a bunch of *****
To be fair the game probably did cost a lot of money to make so I can understand the £49.99 price point as sales will be low outside the Nvidia promotion. A lot of people will never buy on PC due to Windows Store hassle alone like you have to download the entire 73.3Gb in 1 go without pausing otherwise the windows store resets your download to zero again!
I have paused my download 5 times so far, no resets to 0 yet.
