What char did everyone choose?
Not started yet (just under an hour left on the install), but will be playing Emily first. I figure I've already played Corvo in the last game so why play him again straight away.
So do you have GSync set to "Enable G-Sync for full screen mode"?
I can't get the game to run in full screen, I change the setting in the menu, and it keeps reverting back to borderless.
I have just dropped all settings to Low to see if I cant get a good framerate, it stays around 70 but still feels like absolute ****.
Just played the first mission and really not impressed with performance.
Okay my specs aren't the best (2500K, 290X, 8GB) but I stuck with the recommended settings it chose of all medium. It didnt start too badly, varying between around 80 and down to 40, not great but playable, though it didn't even feel very smooth at the high figures.
There was a weird spot early on where I looked into the throne room and it dropped to 10, but other than that seemed okay. Then I got outside and found several places where it dropped to around 20 making it unplayable in places, especially with the mouse movement somebody else mentioned when it happens.
I just don't understand how they can make a sequel that looks worse than the 4 year old original whilst performing so badly. I had no problems with the original, it looked better as well and I was running it on an older graphics card, and there are plenty of games that look much better than this that I can run well.
Original didnt look as good as this. Nowhere near in fact but you are running it at low-ish settings and comparing it to a game you probably played maxed. Playing on ultra pretty much @3440x1440 and its a very nice looking game in parts but more to do with art direction and design over "MeGA TeXTures!"
Alt tab out and set priority to high at the beginning of each level and that greatly improves performance
Yeah I'm sure it looks great on ultra and I am stuck playing at medium, but the point I'm making (badly) is that at whatever setting I happened to be running the original on, it looked better and ran well.
I'd forgive the performance issues if I was running it at a level that looked impressive, but as I say I've played a lot of games recently that run well and look a hell of a lot better. And yes, I'm running those games at high setting, but I can and they run well.
Thanks for the tip about priority, I've just read that elsewhere as well, though I may wait for the patch and see if there is anything they manage to do.
I set my game to Borderless Windowed Mode and now I can't get it back to "Fullscreen mode". I change it, and it says to save the settings. I click OK and then it's back on Borderless Window Mode!
Normally something I could fix with an .ini file change, but not seeing one in the documents folder for Dishonored 2. Anyone been able to fix this issue?
SLI users... people are reporting improved performance using the Witcher 3 bits 0x080020F1. I tried it and it introduced ghosting but turning antialiasing down to fxaa (high) sorted things out. Getting 90% usage on both cards now and a significant framerate improvement.
No problem. Apparantly the patch will sort that out. I do get what you are saying though and they did say it would take quite a beastly PC to max it but I have a feeling the patch will ease a lot of problems people are having
Have I missed something or are there no keys for turn left/ turn right ?
I've only played for an hour but turning seems to be by side stepping with strafe and steering with the mouse which I find rather awkward
