Thanks will have a look. Trigger controllers are definitely not easier for kids. Give one to mine and they struggle, give them stick type and away they go. Who on earth would make a controller with a little steering wheel where forward goes right and backward goes left!
Why didnt they put the wheel on the back, would make more sense.
My lad used the trigger controllers from the age of 4 and to be honest found it easy to hold. No way he could have reached stick controls on a full size controller. It does not take them long to work out the orientation of the wheel, they pick it up in no time. Most RC cars are wheel type controllers so may as well start off with what is most used.
it will probably go across your back garden in about 1.5 seconds though. think it will do 40mph on 2s so you better have a bigass garden!
