- 25 Mar 2004
- Fareham
Defaults to white and full brightness. Would be handy if they were capable of reverting to the previous setting but all the colour info etc is stored in the hub, not the bulb.
This is one of the issues for sure, however you can work around it somewhat with a Hue Dimmer Switch.
The Dimmer Switch can be configured so that subsequent pressed of the power on button set different "scenes", and these scenes are your own settings for what bulbs are turned on, and what colour/brightness settings each one has.
This means if I unplug a lamp or power cycle a wall switch, then tapping the dimmer power off and on again will reset all bulbs to my preference settings again.
Is there a decent option out there yet to replace traditional light switches with Hue compatible ones? Ideally I'd like to replace wall switches with something that incorporates a standard switch and a dimmer control but I can't see anything.
App control is great, but when you're not dimming etc it would be nice to just be able to switch things on and off easily.
Not yet, the Hue Dimmer Switch seems to use the US style dimensions. If they released a UK style size one, then you could potentially replace the whole socket, but the dimmer switch can't ultimately power the bulb on or off, in fact it needs the bulbs to have "powered on" states for it to work, and then you control the light brightness etc.
A question from me on anyone who has implemented the newish motion sensors, are they good? I'm looking at getting two of them in my hallway, one for downstairs, and one for the hallway upstairs.
My current setup is 4 x hue colour changing bulbs in the living room, and 3 x white ambiance bulbs in the hallway. I am looking to expand with a couple of accent lights in the living room. I don't see the need to have hue bulbs everywhere though.
