- 6 Jan 2013
- Rollergirl
You can buy a 1080 now cheaper than what you could get a GTX 7900 for
https://www.asus.com/Graphics-Cards/EN7900GTX2PHT512M/
Yea... that's the point I'm making.
The point was that tech was never cheap and when something new comes out it costs a hand and a leg...
Remind me again ?![]()
OK, I'll bite (just this once, mind).
Increments of the same thing, refreshed and updated with refinements but essentially the same as before should not result in escalating prices.
Giving examples of components that cost a fortune when they first came to market does not justify a component that has escalated in price with a minor incremental step.
Just like this.
A Cpu from 2008 with a GTX 1080 plays the same with a 2015 chip
Now play the same game with the same CPU and a GFX card from 2008 and 2015
It will not play the same.
A 1080 isn't something new, it's just an updated version of what already exists.
We're not comparing a GPU from 2008 with a GPU from 2015, we're comparing a GPU from 2015 with a GPU from 2016.
there is no GPU from 2015 equivalent to this GPU from 2016 and if you don't like the price just buy whatever you think it's worth your money, why all the fuss?
We're not comparing a GPU from 2008 with a GPU from 2015, we're comparing a GPU from 2015 with a GPU from 2016... Titan X (M) ($999) - Titan X (P) ($1200)
Its called performance per watt...
Until capitalism ends, and it probably will do one day, at least capitalism how we know it, that's the way it will always be. If AMD were in the same position their products would be as expensive too. You sell to optimise profits.Nvidia have increased the price from 9 series to 10 series because they can, because they have no competitor. It's driven by capitalism not innovation.
Until capitalism ends, and it probably will do one day, at least how we know it, that's the way it will always be. If AMD were in the same position their products would be as expensive too. You sell to optimise profits.
This is like, an equation or something?
Or did you just see that both the examples I posted have the same TDP, so you decided to attribute the price increase to that instead of the new technology analogy you've been pushing previously?
Your justification seems to be in some sort of metamorphosis.
Just like this.
Yes They have the same TDP But Titan X Pascal is 60% faster.
This equation, it's : Price = Performance / Watt
OK... for Titan (P) the Watt measurement is 250, and the price measurement is 1200.
1200 = P / 250
Therefore:
Performance = 1200 * 250 = 300,000
Titan X (M)
999 = P / 250
Therefore:
Performance = 999 * 250 = 249,750
So, the increase in performance per watt between the 2 cards is 300000-249750 = 50250. And the performance increase percentage is (50250/249750)*100 = I'll give you a clue, it's not 60.
Your sums don't add up, do they?
Admit it, you're just making this up as you go along, aren't you.![]()
I have no idea what you just posted.
Its still performance per watt...
I'm not poor so don't really care...And I will never buy a Titan![]()
