- 5 Sep 2011
- Surrey
Damn, I hope Ryzen delivers, I don't want to have to wait until well into 2018 for a 6 core upgrade.The 6-core chips are codenamed Coffee Lake, and they're due in 2018.
Cannonlake is a die shrink of Kaby Lake that's due in late 2017 but will only appear in mobile chips. Basically it is not of interest to desktop users (similar to Broadwell). Icelake, a new architecture on 10 nm that at least in theory should be released in desktop variants, is also due in 2018. I would not be the least bit surprised if that date slips.
It's been around awhile on server platforms, although the offset register is non adjustable there. So it's not simply when used out of spec. It's because Intel acknowledged the current that the instruction set can pull under certain conditions.
That tells you all you need to know about the potential it has for harm in conjunction with overclocking.
server (and now desktop) cpu`s which use AVX, has the feature to reduce cpu speed automatically , and this is set to auto by default. once the cpu goes past power loading it throttles back. in fact desktop boards do this when using AVX , its only of recent that a UEFI update exposed the auto function to allow it to be user modified (all skylake boards would run AVX-256 instructions in auto mode)
Thats Bulldozer/Piledriver, or at least it is in 8 thread hyperthreaded mode, 4 thread combined its 256Bit...... one of its problems, isn't Zen using 256Bit FPU's?
It's using a 128 bit FMAC unit:
http://www.anandtech.com/show/10591...t-2-extracting-instructionlevel-parallelism/7
I'm just checking that Intel are not planing on following up Ryzen this year with their consumer 6 cores.
^^ again be careful with this speculation.....X299 Skylake E is a power house platform.
Skylake-E isn't the normal "consumer" grade i7 its the "enthusiast" chip, we have had hexa cores on the intel "X" platform chips for quite a while like the 5820K, these are also lacking IGP
AMD will have quad / hex and octa core consumer grade APU's with good IGP (probably) this year
But not due in 2017?
Platform semantics. I know what I'd rather have between Ryzen and an 8 core SKL.
