To be expected now as MPSS are EOL for anything other than specific sizes where they have manufacturer contracts in place (I.e. * marked for certain BMWs).They are cheaper than MPSS in Em free sizes
Can you get Goodyear Eagle F1 Asymmetric 3 tyres in 275/35/19?
I can get them for £150 each in 245/40/19 for the fronts but everywhere I check only has the 2 in the rear sizes
EDIT - Just seen them on Camskill for £185, are Camskill any good?
I really don't need new tyres, but I wouldn't mind replacing my run flats and since the insurance repair, I have two new tyres on one side and half worn on the other, and it drives me nuts knowing that![]()
So I'm replacing my punctured tyre tomorrow, the other front has just over 6mm of tread left on it, is this close enough that I shouldn't worry about changing that too, or should I replace both to be safe?
May have to try the PS4S next then.
Still fancy the PS4S mind....
I have one of those super fancy oil damped pressure gauges (GET ONE NOWWW!!!)
6mm? Nothing to worry about there.
I bought it from Demon Tweeks. Let me see if I can find it but think it was around 70 quid.Any chance you can post a link to some?
I want a new pressure gauge as I'm sick to death of the michelin one that I have as it's a right PITA if not perfectly straight when checking pressures.
You won't regret it.
http://www.demon-tweeks.co.uk/perfo.../intercomp-ultra-deluxe-tyre-pressure-gauge-2Any chance you can post a link to some?
Brilliant thanks, looks like I have an excuse for a drive down to Wrexham now then
Then buy the ten pound one with your money![]()
Well it's oil damped and that helps consistency of measurement. It's rugged and weighty so that helps longevity. It's easy to use and read which is nice and it allows me to remove air via a valve when attached and I wanted known accuracy for road and track. Like an expensive watch it just tells the time but unlike an expensive watch accurately every timeI was simply interested to know what a £70 tyre pressure gauge offered over a £10-15 one with proven accuracy against a calibrated device?
