How inept is that, AMD have left out color options, back to Nvidia I go.
They removed the colour options, they said if enough people keep asking them for them to come back, then they'll consider it
I understand the reason as some monitors especially asus have poor color and gamma defaults without the control to change them. On the asus we have to use one of the presets for better color but it crushes black. On the older drivers we would use standard and just add some saturation to fix it.I can understand some people higher the brightness us for games like Dayz, Monitor has option "Black equalizer" But for Colours do you guy change all the time? Why not just calibrate your monitor the correct way using built in Monitor settings and be done with it?
Am sure these settings will come back within time you after remember here I hearing 80% of the AMD driver team is working on VEGA drivers for release.
No adaptor no, one cable with "normal" DP on one end and mini-DP on the other.
I've been playing Steep, another Ubi game, with Freesync working just fine but The Division always seems to be problematic (note that it used to work fine, but that was months ago).
Settings still there for me...
NIt's a pretty poor show from AMD. My PC couldn't be any more basic. It's a 4790k, 8gb's of ram, Win 10 pro and one Fury tri-x. Nothing unusual yet Crimson seems awfully slow if you have a lot of games installed. I have 6 tb's of HDD space with over 1000 games installed on it and moving between windows in Crimson has a delay which has an 'it isn't responding' message if you get impatient and press it again. There's at least a 6 or 7 second delay before anything you do gets a response. RAPTR was quicker as was CCC ffs.
I don't run Afterburner usually. I noticed the fps was below 30 when it's usually above 60 because it was not smooth so using Steams in game fps counter it told me it was that low so I ran gpu-z which told me it was hanging around at 300 to 500 on the core.
I then started Afterburner to see if it could be pushed up by adding a small over clock but it did nothing so I put it all back to stock turned the pc off and turned it back on after dinner to try again.
It was still the same.
 ) is going to have to take some time when it comes to profile loading. Your use scenario is extremely niche im afraid. I myself have a 500gb drive and 300gb of a 1tb mechanical drive full of games and yet Radeon Settings are loading near instant, no more than 0,5 of a second. But dont get me wrong. I get the frustration. I to would be frustrated if i had the same issue as you. Infact i was when i had nvidia in the computer.
 ) is going to have to take some time when it comes to profile loading. Your use scenario is extremely niche im afraid. I myself have a 500gb drive and 300gb of a 1tb mechanical drive full of games and yet Radeon Settings are loading near instant, no more than 0,5 of a second. But dont get me wrong. I get the frustration. I to would be frustrated if i had the same issue as you. Infact i was when i had nvidia in the computer.For me, the first few relive drivers have been incredibly buggy so I cba trying them out again until a few more updates to polish them furtherReally don't understand why you don't just try the latest drivers. What's the worst that could happen?
Besides, no need for me as I don't need any of the latest changes + I don't use any of the new features anyway.
Ah ok, sounds like they have much improved then! Will hold of for now though, not playing any of the latest games etc. so don't need any of the improvements etc. yet.these ones are the first of the ReLive batch that haven't given me a nightmare with black screens, screen corruption on 2nd monitor, core clocks sticking, system freezes....the list goes on.
I think you should give these a go Nex mate, like I said these are the best ones of the bunch so far.
Still there for me, as still on the 16.3 hotfixes
 , I might even move across to the dark side
They better bring them back by the time I upgrade my 480 or I'll go back to Nvidia just for the colour settings etc...
Personally rather have saturation, colour settings back then the Relive crap.
If you guys want to start a thread on the AMD forums to ask for these colour options to be reinstated, I'll ensure your voice is heard internally.
Ill give The Division a try myself. I know they broke native fullscreen in patch 1.5 and for some reason haven't fixed it yet. The windowed freesync support we are suppose to have in ReLive never worked for me sadly in any game that ive tested with the exception of one(cant remember the name).
