I ofcourse tested this and do understand but can't share yet.....
Low end boards vrm is causing throttle issues so I suggest those wanting to buy for performance get a suitable board. Asus crosshair or similar.
also would like to know this..Is the MSI Carbon a decent option too 8pack?
Really you want a cooler blowing down onto the board,
I believe the Cryorig AiO does this.
That's good actually, on par with Intel's 8 core chips. The real question is whether the 6 and 4 core parts can clock higher or not...in fact that may be one of the reasons they aren't releasing them straight away, in order to buy more time to improve the clocks.seen another site is offering the 1800x with a overclock of 4.2 lol
To infer that that OC don't understand cooling is frankly ridiculous! Are you plucking these things out of thin air or out of an Xmas cracker!On top of all of that, OCUK are talking about overclocking but were they not using an AIO while also talking about VRM issues? So the question I have is, did they have any actual directed airflow at the VRMs. Largely because they are all designed with these stupid flat tops which prevents a lot of airflow. Really you want a cooler blowing down onto the board, either fan on top of a heatsink such as the 1700 stock cooler, or a fan somewhere to blow air at the board and which would then blow through the VRM heatsinks.
I think the idea that you need a £250 mobo to overclock well us utterly ridiculous and frankly don't believe it, I'm wondering if their testing method was simply faulty and didn't cool the VRMS, hence only the stupid expensive board with cooler running/larger number of VRMs worked well.
Doubt it. Count the VRMs. Only the Asus Crosshair, ASRock X370 Taichi, & ASRock Fatal1ty X370 Professional Gaming seem to be sporting high-end VRMs.Is the MSI Carbon a decent option too 8pack?
I would suggest a performance air cooler blowing air across the VRM's to the top exhaust fan. Worked for me on an OC FX8350 on an M5A99x board. Need not be noisy either. AIO's tend to remove heat from the CPU and not the chipset or VRM areas. Also do not block up all the exhaust fans with a radiator.
People don't seem to understand that most of these AM4 boards are sporting really crappy hardware. We'll hopefully start seeing decent alternatives soon.To infer that that OC don't understand cooling is frankly ridiculous! Are you plucking these things out of thin air or out of a Xmas cracker!
Have you considered that the boards just aren't up to it? Wht not contact Gibbo or 8 Pack directly with your reservations.
Seems like a throwback...higher end CPU coolers have been tower-style for a decade, right?Maybe this style of cooler will get some decent results due to more airflow down on the the VRMs?
My basket at Overclockers UK:
Silver Arrow? I have this on my 2500k @4.5. Temps Never go above 55 while playing games![]()
Or this![]()
