I'm fortunate enough to have a stack of Win10 keys in my desk at work! Each time I get a motherboard replacement on a laptop at work I get a free one lol
Want to send me one
I just call Microsoft and they sort it out in no timeI'm fortunate enough to have a stack of Win10 keys in my desk at work! Each time I get a motherboard replacement on a laptop at work I get a free one lol
handy to know cheersIf new Motherboard install it first without reinstall, load up windows, go online.... that will change your hardware association with the key to the new board, then reinstall.
Is the key for windows 10 the same one used for windows 7 if you upgraded?
No you should have received a new one when you went through the free upgrade process (assuming that's what you did)
Another unboxing, this time by Paul @ Newegg USA. He also received the Gigabyte Aorus GA-AX370-Gaming 5, however, he notes in the video that motherboards sent out to by AMD in the reviewers kit were random and also included the MSI X370 Xpower Gaming Titanium and Asus ROG Crosshair VI Hero. So when the NDA is lifted we can expect reviews from those three motherboards from the off. In the background on the wall, notice he has the ASRock X370 Taichi.AMD Ryzen test review kit unboxing. These contained 1800X, Gigabyte Aorus GA-AX370-Gaming 5, Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz (v5.30 Hynix), Noctua NH-U12S SE-AM4 Cooler.
I was of the understanding that at this point (assuming upgrade of Win 7 or Win 8/8.1 to Win 10) if you go and do a full system upgrade (CPU, Mobo, Ram at least) then your current Windows 10 license will NOT be transferable. MS changed the licensing scheme with Win 10. I'm not 100% but I believe this is the case.
No Win 10 key was needed. You just run the updater on your current Win 7, Win 8/8.1 and it would upgrade your current key to a Win 10 key. This gets tied to your hardware. You can make small changes. Such as single components, but wholesale changes will need the purchase of a new Win 10 license.
Again, this was my understanding.
I thought that might be the case but not sure. This is how to find your updated key apparently. Just save in notepad as a .vbs file and run it.
Set WshShell = CreateObject("WScript.Shell")
MsgBox ConvertToKey(WshShell.RegRead("HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\DigitalProductId"))
Function ConvertToKey(Key)
Const KeyOffset = 52
i = 28
Chars = "BCDFGHJKMPQRTVWXY2346789"
Do
Cur = 0
x = 14
Do
Cur = Cur * 256
Cur = Key(x + KeyOffset) + Cur
Key(x + KeyOffset) = (Cur \ 24) And 255
Cur = Cur Mod 24
x = x -1
Loop While x >= 0
i = i -1
KeyOutput = Mid(Chars, Cur + 1, 1) & KeyOutput
If (((29 - i) Mod 6) = 0) And (i <> -1) Then
i = i -1
KeyOutput = "-" & KeyOutput
End If
Loop While i >= 0
ConvertToKey = KeyOutput
End Function
OEM licenses are not transferable, retail ones are. Windows will deactivate on the new hardware, but should re-activate fine although it may take a phone call to MS to get an activation code. The free upgrade copies of Windows 10 apparently take their OEM/retail status from the original OS. As of the anniversary update Win 10's licence can be associated with a Microsoft account, so that can also be use to transfer the licence to new hardware.I was of the understanding that at this point (assuming upgrade of Win 7 or Win 8/8.1 to Win 10) if you go and do a full system upgrade (CPU, Mobo, Ram at least) then your current Windows 10 license will NOT be transferable. MS changed the licensing scheme with Win 10. I'm not 100% but I believe this is the case.
For anyone unsure of their Windows licence type, open a command prompt and type slmgr -dli. That will show the licence type.
