Is there any future to the am4 socket and chipset? Will it just work with ryzen or is it planned to be compatible with the next generation of ryzen cpu?
Is there any future to the am4 socket and chipset? Will it just work with ryzen or is it planned to be compatible with the next generation of ryzen cpu?Meant to be using AM4 for the next 4 years or something like that.
sausages
4 Generation of Zen, apparently, one new Zen chip per year.
That leak, thanks for posting that. Crazy...Yet another tick with AMD ....someone should do a list why some one should go with AMD so far i have Intel with poor TIM hs , expensive per core , new socket every hour , expensive again , 0000.1% IPC increase per release , bribing OEM's , on on
Anyway we do not seem to be getting any solid Ryzen leaks ...
so this will have to do
That's what I did, just don't remember getting another key...
thanks for the link, i knew it could be done this way but not howI upgraded from Win7 to Win10, I plan to install the new mobo and boot from the drive, reactivate Windows 10 then I'll probably do a fresh install. I saw a guide here on how to do it, if you have a Microsoft account linked to your main logon then I believe your licences get linked to your account so it's easy to recover it.
http://www.windowscentral.com/how-re-activate-windows-10-after-hardware-change
Gibbo - any ETA on X370 Micro-ATX motherboards
As far as I've found only Biostar have an X370 mATX board and I'm not actually convinced it's anything special over the X350.
My point is Biostar isn't doing a whole lot in its implementation of x370 on mATX and it certainly isnt making sli/xfire possible: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=871#specificationx370 has more pcie lanes so can do sli. seems the biggest difference. The boards tend to have more power phases, but that's not really down to the chipset afaik
its new and shiny so no justification neededI am sooo damn tempted to go 1800X - X370 Crosshair Hero - and 32GB 3200Mhz. I can't justify it at all though; it'll be a minor upgrade; but my goodness am I tempted. Haven't had a full AMD system since my 2009 Phenom II build.
