Then why havent I ever had any stutters and I've put 100's of hours into GTAV?
4.2ghz is highest overclock on 1700.
I don't really understand so much disappointment.
Indeed weren't we told that Ocuk were the place to go for AMD because they had some sort of deal with them for a large amount of stock and early delivery ? haha
I'm sorry, but i can tell you for a fact that on both GTAV and ROTTR which I own and play, I have never had frames drop below 60 or ever have any stuttering at all. And I run both fully maxed. I'm not trying to dismiss reviews, but his findings just aren't accurate.
ETA is saying 17th March on the store, would hope that's for a second batch and not the first.So whens the 1800x in stock ?
There are also some notable reviewer absences, TPU, Toms Hardware, PCPer, jayz2cents... are they still grappling with BIOS updates?
Although the stages have moved through to completion in about half an hour instead of a few months. I went out to do a job in the middle of a grief spin and come back to a chirpy content glow.this reminds me of a typical amd release, loads of hype, then disappointment then after the dust has settled everyone realises well its not too bad after all
With the rysen cpu-z 1.78 leak it's not clear of the turbo speed during the st and mt test,
The baseclock is identified as 3.450 ghz but we need to see a prinout of per core speeds.
Still snifing at 1900 st is pretty good if it's at 3.7ghz for st. My I5 3570k at 3.8ghz st would get 1650.
If the ryzen can get into the 2100's around 4.0ghz-4.2ghz then i'll be impressed.
Alpha something or other wasn't it. More expensive than others as well.
I think it's because the big sites use semi-automated/unattended test setups, so they are a pain to update.
Indie's probably do it all like we would and have the latest software/firmware/updates and best settings for each.
Its disappointing when SMT losses 10% of the performance in games in the Hardware.fr review,ie,the Core i7 6900K is only 10% ahead with SMT disabled.
Its just how AMD always has some bug or issue during a launch - if they were more open about it the CPU would have looked better in gaming benchmarks.
Lol.You have a quantum computer.
