Ok your probably not going to like this, but send that 1800x back and get the 1700, it seems the 1700x and 1800x being leakier parts are around 20c on average hotter than the 1700 even when OC'das 8Pack has said, they are designed for high cooling, if your going custom water loop you may find it reasonable, but i can also imagine, if your worried about temps, you probably wont be impressed by the temps of that CPU.
Not worried about temps as such just rad volume, i have so many rads from my full custom build years back and i managed to keep two 7990's under good temps. It's just do i go with a 240 push pull or stick in another 240 along with it.
I should have worded my OCD better, i actually like the challenge of keeping things cool that are known to get hot.
Did 8pack give any temps when he mentioned the 240AIO ?
Ive given up reading through more than 2 pages of this thread at a time because it moves so quick
